Salta al contenuto principale
Insignia Flex 8 NS-15AT08 Back Casing Replacement
Cosa ti serve
  1. Insignia Flex 8 NS-15AT08 Back Casing Replacement, Back Casing: passo 1, immagine 1 di 2 Insignia Flex 8 NS-15AT08 Back Casing Replacement, Back Casing: passo 1, immagine 2 di 2
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Back Casing Replacement: passo 2, immagine 1 di 2 Insignia Flex 8 NS-15AT08 Back Casing Replacement: passo 2, immagine 2 di 2
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
Conclusione
Baylor, Team 6-7, Williams Fall 2015 Membro di Baylor, Team 6-7, Williams Fall 2015
BU-WILLIAMS-F15S6G7
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 475
