Salta al contenuto principale
Insignia Flex 7 Camera Assembly Replacement
Cosa ti serve
  1. Insignia Flex 7 Camera Assembly Replacement, Battery: passo 1, immagine 1 di 3 Insignia Flex 7 Camera Assembly Replacement, Battery: passo 1, immagine 2 di 3 Insignia Flex 7 Camera Assembly Replacement, Battery: passo 1, immagine 3 di 3
    • Insert the edge of the plastic opener into the grove between the screen and back cover around the perimeter of the device.
    • Then using a gentle prying motion, create a gap large enough to use your fingers to separate the two halves.
  2. Insignia Flex 7 Camera Assembly Replacement: passo 2, immagine 1 di 2 Insignia Flex 7 Camera Assembly Replacement: passo 2, immagine 2 di 2
    • Place the tip of the spudger on each side of the battery's electrical connector.
    • Then using a gentle match-striking motion, loosen both sides of the battery's electrical connector.
  3. Insignia Flex 7 Camera Assembly Replacement: passo 3, immagine 1 di 3 Insignia Flex 7 Camera Assembly Replacement: passo 3, immagine 2 di 3 Insignia Flex 7 Camera Assembly Replacement: passo 3, immagine 3 di 3
    • Insert the flat end of the spudger under one side of the battery.
    • Then using a gentle prying and sliding motion, separate the battery from the case. There are two lengthwise strips of glue holding it down.
    • Repeat the process for the other side of the battery.
  4. Insignia Flex 7 Camera Assembly Replacement, Motherboard: passo 4, immagine 1 di 2 Insignia Flex 7 Camera Assembly Replacement, Motherboard: passo 4, immagine 2 di 2
    • Locate the three ribbon cables connecting components to the motherboard. The connections are covered with orange shielding tape. Peel the tape off the connectors and reserve for reassembly.
  5. Insignia Flex 7 Camera Assembly Replacement: passo 5, immagine 1 di 3 Insignia Flex 7 Camera Assembly Replacement: passo 5, immagine 2 di 3 Insignia Flex 7 Camera Assembly Replacement: passo 5, immagine 3 di 3
    • Each Zero Insertion Force or ZIF connector has a latch which holds the ribbon cable in place. The camera cable (a) and the LCD display cable (b) have a latch that lifts as shown in the illustration. Use a spudger to gently lift the latch to release the cable.
    • The touchscreen cable (c) has a sliding latch on each side of the connector. Use a spudger to carefully slide the latch on each side as shown to release the cable.
  6. Insignia Flex 7 Camera Assembly Replacement: passo 6, immagine 1 di 3 Insignia Flex 7 Camera Assembly Replacement: passo 6, immagine 2 di 3 Insignia Flex 7 Camera Assembly Replacement: passo 6, immagine 3 di 3
    • Using a Phillips #000 screwdriver, unscrew the six 4.8mm screws holding the motherboard to the case.
    • Using the spudger lift the motherboard from the case.
  7. Insignia Flex 7 Camera Assembly Replacement, Camera Assembly: passo 7, immagine 1 di 3 Insignia Flex 7 Camera Assembly Replacement, Camera Assembly: passo 7, immagine 2 di 3 Insignia Flex 7 Camera Assembly Replacement, Camera Assembly: passo 7, immagine 3 di 3
    • Insert the flat end of the spudger into the groove between the external camera and the tablet's plastic case. Then, applying a gentle prying motion on both sides of the camera, loosen the glue holding down the external camera to separate it from the plastic case.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 148
