Salta al contenuto principale
Insignia Flex 7 Battery Replacement
Cosa ti serve
  1. Insignia Flex 7 Battery Replacement, Battery: passo 1, immagine 1 di 3 Insignia Flex 7 Battery Replacement, Battery: passo 1, immagine 2 di 3 Insignia Flex 7 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Insert the edge of the plastic opener into the grove between the screen and back cover around the perimeter of the device.
    • Then using a gentle prying motion, create a gap large enough to use your fingers to separate the two halves.
  2. Insignia Flex 7 Battery Replacement: passo 2, immagine 1 di 2 Insignia Flex 7 Battery Replacement: passo 2, immagine 2 di 2
    • Place the tip of the spudger on each side of the battery's electrical connector.
    • Then using a gentle match-striking motion, loosen both sides of the battery's electrical connector.
  3. Insignia Flex 7 Battery Replacement: passo 3, immagine 1 di 3 Insignia Flex 7 Battery Replacement: passo 3, immagine 2 di 3 Insignia Flex 7 Battery Replacement: passo 3, immagine 3 di 3
    • Insert the flat end of the spudger under one side of the battery.
    • Then using a gentle prying and sliding motion, separate the battery from the case. There are two lengthwise strips of glue holding it down.
    • Repeat the process for the other side of the battery.
Conclusione
Altre 2 persone hanno completato questa guida.
2 Commenti
Link for replacement battery?
Mike - Replica
I'm also looking for a replacement battery and i've only found batteries with two cables instead of the 5 this one has
Jose Garza Lozano - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 961
