Salta al contenuto principale
Insignia Flex 10.1 NS-P10W8100 Camera Replacement
Cosa ti serve
  1. Insignia Flex 10.1 NS-P10W8100 Camera Replacement, Camera: passo 1, immagine 1 di 2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement, Camera: passo 1, immagine 2 di 2
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
  2. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: passo 2, immagine 1 di 2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: passo 2, immagine 2 di 2
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to each side to help pry the back cover evenly.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: passo 3, immagine 1 di 1
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off work your fingers around the corners and slowly pry the cover off using your fingers.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: passo 4, immagine 1 di 2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: passo 4, immagine 2 di 2
    • Carefully remove the yellow tape holding down the camera ribbon connector by pulling it upwards.
    • Remove the black tape holding down the camera ribbon connector which is attached to the motherboard.
  5. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: passo 5, immagine 1 di 2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: passo 5, immagine 2 di 2
    • Disconnect the zero insertion force (ZIF) connector by using your fingernail to flip the small locking flap.
    • Disconnect the cable by gently pulling it outward.
  6. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: passo 6, immagine 1 di 3 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: passo 6, immagine 2 di 3 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: passo 6, immagine 3 di 3
    • Remove the camera by pulling it upward.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 206
