Salta al contenuto principale
Insignia Flex 10.1 NS-P10A7100 Battery Replacement
Cosa ti serve
  1. Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: passo 1, immagine 1 di 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: passo 1, immagine 2 di 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Use the blue iFixit opening tool to remove the backing of the device.
    • Wedge the tool in the crease between the device backing and screen.
  2. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: passo 2, immagine 1 di 2 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: passo 2, immagine 2 di 2
    • Disconnect the larger ribbon that runs along the top of the battery and connects to the motherboard.
    • Lift up the connector by pulling it up with your fingernail. The ribbon will then be released and you can detach it.
  3. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: passo 3, immagine 1 di 2 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: passo 3, immagine 2 di 2
    • Detach the five colored wires that connect the battery to the motherboard.
    • Use two fingers and place one on either side of the white plastic encasing the wires.
    • Pull on this piece to release it from the motherboard.
    • Now the battery is detached from the motherboard.
  4. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: passo 4, immagine 1 di 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: passo 4, immagine 2 di 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: passo 4, immagine 3 di 3
    • The battery is now only connected to the device by the glue on the bottom.
    • Use the iFixit opening tool to wedge the battery off of the device. You will have to use some force to pry the battery off of the device.
    • Now that your battery is removed it is ready for replacement.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,001
