Introduzione
If the camera is not working properly or takes distorted photos, you may need to replace the camera. There are no significant hazards to be aware of, but it's always a good idea to be careful when removing parts of your device as to not damage anything.
Cosa ti serve
Position the tablet with the top edge by the camera facing down.
Insert the plastic opening tool between the front panel and back case at the upper left hand corner of the tablet.
Using the Phillips #000 screw driver, unscrew the two 4 mm screws securing the camera to the front panel in a counterclockwise direction.
The camera is now free from the device and can be replaced. To reassemble your device, follow these instructions in reverse order.
