Salta al contenuto principale
Insignia Flex 10.1 NS-P10A6100 Back Case Replacement
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Insignia Flex 10.1 NS-P10A6100 Back Case Replacement, Back Case: passo 1, immagine 1 di 1
    • Make sure your tablet is turned off and not connected to a power source to prevent personal injury.
    • The volume rocker and power button located on the top edge by the camera are not connected pieces and will become free from the device once the front panel is removed from the back case. They are easily put back in place when reassembling the tablet.
    • Position the tablet with the top edge by the camera facing down.
    • Insert the plastic opening tool between the front panel and back case at the upper left hand corner of the tablet.
  2. Insignia Flex 10.1 NS-P10A6100 Back Case Replacement: passo 2, immagine 1 di 2 Insignia Flex 10.1 NS-P10A6100 Back Case Replacement: passo 2, immagine 2 di 2
    • Slide the plastic opening tool along the edge of the tablet between the front panel and back case.
    • Repeat this process for the two shorter edges of the tablet leaving the top edge by the camera still snapped in place.
  3. Insignia Flex 10.1 NS-P10A6100 Back Case Replacement: passo 3, immagine 1 di 1
    • Using an unfolding motion along the top edge of the tablet, carefully separate the front panel from the back case.
Conclusione
Baylor, Team 5-8, Williams Fall 2016 Membro di Baylor, Team 5-8, Williams Fall 2016
BU-WILLIAMS-F16S5G8
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 40
