Salta al contenuto principale
Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement
  1. Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement, Rubber Gasket: passo 1, immagine 1 di 1
    • Remove lid and place upside down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement: passo 2, immagine 1 di 2 Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement: passo 2, immagine 2 di 2
    • Grab the edge of the clear rubber gasket and slowly peel it off the lid.
    • Continue peeling off the gasket until it is completely detached from the lid.
Conclusione
Savannah Webb
Membro da: 01/18/18
657 Reputazione
5 Guide realizzate
Cal Poly, Team S12-G3, Banghart Winter 2018 Membro di Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Membri
5 Guide realizzate
3 Commenti
Am having trouble Turning the lid from Unlock to lock. The pin comes out in the back when I go to turn it from unlock to lock. Can you help me?
pclarkrob3 - Replica
I bought the insignia pressure cooker at a garage sale but, the rubber gasket smells bad. I’ve cleaned the entire cooker but, that gasket stinks like no other
Chuck Smith - Replica
I am having the same problem as the first comment by pclarkrob3 I am having trouble turning the lid from unlock to lock. These are really crappy instructions!!!! I have only used my pressure cooker twice so everything is still new.
Vivian Lang - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,234
