Salta al contenuto principale
Insignia 6-Quart Pressure Cooker Float Valve Replacement
  1. Insignia 6-Quart Pressure Cooker Float Valve Replacement, Float Valve: passo 1, immagine 1 di 1
    • Remove the lid and place it upside-down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Float Valve Replacement: passo 2, immagine 1 di 1
    • Pinch the rubber gasket on the float valve and pull up.
  3. Insignia 6-Quart Pressure Cooker Float Valve Replacement: passo 3, immagine 1 di 2 Insignia 6-Quart Pressure Cooker Float Valve Replacement: passo 3, immagine 2 di 2
    • Pull the rubber gasket off of the metal rod.
    • The valve will fall out of its hole onto the table. It can now be cleaned or replaced.
    • You may find it helpful to push up on the float valve from the other side of the lid while you remove the gasket.
Conclusione
Altre 3 persone hanno completato questa guida.
Savannah Webb
Membro da: 01/18/18
657 Reputazione
5 Guide realizzate
Cal Poly, Team S12-G3, Banghart Winter 2018 Membro di Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Membri
5 Guide realizzate
3 Commenti
I received the replacement valve and pot. Now my insignia instapot won't hold pressure. It keeps seeping steam/spritz out of the float valve. I am ready to toss it in the trash. It worked bafore I replaced that stem. I should've kept it.
Carole Neider - Replica
OK after much digging, I found the old valve and now it is pressurizing.
where can I buy the float valves
valuacion.urbanismo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 76
Tutti i Tempi: 4,509
