Salta al contenuto principale
Insignia 6-Quart Pressure Cooker Circuit Board Replacement
Cosa ti serve
  1. Insignia 6-Quart Pressure Cooker Circuit Board Replacement, Circuit Board and Power Cord: passo 1, immagine 1 di 1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw.
  2. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 2, immagine 1 di 1
    • Twist the light grey plastic until the holes align with the blockers.
    • Remove the light grey plastic cover.
  3. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 3, immagine 1 di 1
    • Remove the power cord from the slot it is inserted in.
  4. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 4, immagine 1 di 1
    • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
  5. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 5, immagine 1 di 1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
  6. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 6, immagine 1 di 1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
  7. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 7, immagine 1 di 1
    • Pinch the small white component connected to the circuit board.
    • Once pinched, wiggle this component until it is disconnected.
  8. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 8, immagine 1 di 1
    • Pinch the red component connected to the circuit board.
  9. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 9, immagine 1 di 1
    • Wiggle the wide white component until it is removed from the circuit board.
  10. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 10, immagine 1 di 1
    • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
  11. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 11, immagine 1 di 1
    • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
  12. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 12, immagine 1 di 1
    • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
  13. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 13, immagine 1 di 1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
  14. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: passo 14, immagine 1 di 1
    • Remove and replace the circuit board.
Conclusione
Altre 9 persone hanno completato questa guida.
Savannah Webb
Membro da: 01/18/18
657 Reputazione
5 Guide realizzate
Cal Poly, Team S12-G3, Banghart Winter 2018 Membro di Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Membri
7 Guide realizzate
8Commenti sulla guida
Where do you purchase the circuit board
Douglas Koons - Replica
Hi, thanks for the guide. Where could I purchase the circuit board?
Anthea - Replica
Please, Where can I buy the electrical circuit?
Mohammed - Replica
why is my circuit board not fixed to the top like in the diagram
david stanley - Replica
where can I purchase the circuit board
de27@bellsouth.net - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 49
Tutti i Tempi: 3,806
