Salta al contenuto principale
Infant Optics DXR-8 Power Button Replacement
Cosa ti serve
  1. Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: passo 1, immagine 1 di 3 Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: passo 1, immagine 2 di 3 Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: passo 1, immagine 3 di 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Power Button Replacement: passo 2, immagine 1 di 3 Infant Optics DXR-8 Power Button Replacement: passo 2, immagine 2 di 3 Infant Optics DXR-8 Power Button Replacement: passo 2, immagine 3 di 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Power Button Replacement: passo 3, immagine 1 di 3 Infant Optics DXR-8 Power Button Replacement: passo 3, immagine 2 di 3 Infant Optics DXR-8 Power Button Replacement: passo 3, immagine 3 di 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Power Button Replacement, Power Button: passo 4, immagine 1 di 1
    • The power button is located at the top of the device.
  5. Infant Optics DXR-8 Power Button Replacement: passo 5, immagine 1 di 1
    • Remove the button by picking it up out of the hole it is connected to.
  6. Infant Optics DXR-8 Power Button Replacement: passo 6, immagine 1 di 1
    • Insert a new button by placing the small end in the hole to connect the button to the device.
Conclusione
To reassemble your device, follow the instructions in reverse order.
Altre 3 persone hanno completato questa guida.
2Commenti sulla guida
Where did you get the replacement switch?
Dave Peterson - Replica
Where can you purchase a new power switch on the circuit board for replacement?
Derrick Silvestri - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 36
Tutti i Tempi: 5,466
