Introduzione
If your Infant Optics DXR-8 baby monitor's power button is not responding, jammed, or broken, this guide will help you to replace it. Follow the simple steps described here to safely take out the old button and replace it with a new one.
Make sure to turn off the device and unplug it from the charger before you begin.
Cosa ti serve
Using the plastic opening tool, remove screen protector from front of monitor.
To reassemble your device, follow the instructions in reverse order.
Altre 3 persone hanno completato questa guida.
2Commenti sulla guida
Where did you get the replacement switch?
Where can you purchase a new power switch on the circuit board for replacement?
