Introduzione
The disassembling of the monitor is so to be able to change the screen or replace other components of the monitor.
Cosa ti serve
Start by gently inserting the plastic opening tool between the led and casing.
Glide the tool around the entire cover to reveal the screws, which are 5.0 mm.
Remove the four corner screws, 5.0 mm, using a J1 bit.
Altre 6 persone hanno completato questa guida.
