Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Archiviate
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Archiviate
Introduzione
The disassembling of the monitor is so to be able to change the screen or replace other components of the monitor.
  1. Start by gently inserting the plastic opening tool between the led and casing.
    • Start by gently inserting the plastic opening tool between the led and casing.
  2. Slowly pry the cover away from the bottom using the plastic opening tool.
    • Slowly pry the cover away from the bottom using the plastic opening tool.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Acquista ora
    Acquista ora
  4. Glide the tool around the entire cover to reveal the screws, which are 5.0 mm.
    • Glide the tool around the entire cover to reveal the screws, which are 5.0 mm.
  5. Remove the cover and set it aside.
    • Remove the cover and set it aside.
  6. Remove the four corner screws, 5.0 mm, using a J1 bit. Lift the top away from the bottom using the metal spudger. Be careful not to rip the antenna wire.
    • Remove the four corner screws, 5.0 mm, using a J1 bit.
    • Lift the top away from the bottom using the metal spudger. Be careful not to rip the antenna wire.
Conclusione
Altre 6 persone hanno completato questa guida.
Larsha Johnson
Membro da: 26/08/2015
478 Reputazione
3 Guide realizzate
USF Tampa, Team 6-4, Remmell Fall 2015 Membro di USF Tampa, Team 6-4, Remmell Fall 2015
USFT-REMMELL-F15S6G4
4 Membri
3 Guide realizzate
What is the part number for the LCD?
jstarion - Replica
From the pictures LQ035NC111 seem to be the part number.
Michael C -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 5,825
