Salta al contenuto principale
Infant Optics DXR-8 Camera Speaker Replacement
Cosa ti serve
  1. Infant Optics DXR-8 Camera Speaker Replacement, Infant Optics DXR-8 Camera Disassembly: passo 1, immagine 1 di 2 Infant Optics DXR-8 Camera Speaker Replacement, Infant Optics DXR-8 Camera Disassembly: passo 1, immagine 2 di 2
    • Position the camera with bottom facing toward you.
    • Using the plastic opening tool, remove all four rubber ends from the bottom of the camera.
  2. Infant Optics DXR-8 Camera Speaker Replacement: passo 2, immagine 1 di 2 Infant Optics DXR-8 Camera Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the four 4 mm screws beneath rubber ends using the Phillips #00 screwdriver.
  3. Infant Optics DXR-8 Camera Speaker Replacement: passo 3, immagine 1 di 1
    • Open the bottom of the camera to reveal the circuit board and speaker.
  4. Infant Optics DXR-8 Camera Speaker Replacement, Camera Speaker: passo 4, immagine 1 di 1
    • Disconnect the speaker cable from the circuit board for ease of access.
  5. Infant Optics DXR-8 Camera Speaker Replacement: passo 5, immagine 1 di 1
    • Lift the speaker from the casing using a metal spudger.
    • Place a new 8W speaker in the casing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,199
