Salta al contenuto principale
Infant Optics DXR-8 Battery Replacement
  1. Infant Optics DXR-8 Battery  Replacement, Battery: passo 1, immagine 1 di 3 Infant Optics DXR-8 Battery  Replacement, Battery: passo 1, immagine 2 di 3 Infant Optics DXR-8 Battery  Replacement, Battery: passo 1, immagine 3 di 3
    • Begin by holding the Monitor so that the backside is flipped up. This is where your battery is located.
    • Slide the battery panel downwards to detach it completely. The battery should be completely visible.
  2. Infant Optics DXR-8 Battery  Replacement: passo 2, immagine 1 di 3 Infant Optics DXR-8 Battery  Replacement: passo 2, immagine 2 di 3 Infant Optics DXR-8 Battery  Replacement: passo 2, immagine 3 di 3
    • Now that your battery is exposed, begin to take the battery out. The only thing keeping the battery in the battery port should be the plug.
    • Now unplug the battery from the battery port. The plug is small so be careful locating it.
    • The battery and plug should be completely out of the battery port.
Conclusione
To reassemble your device, follow these instructions in reverse order
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 13-4, Banghart Winter 2017 Membro di Cal Poly, Team 13-4, Banghart Winter 2017
CPSU-BANGHART-W17S13G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 35
Tutti i Tempi: 11,682
