Salta al contenuto principale
Infant Optics DXR-8 Back Cover Prerequisite
Cosa ti serve
  1. Infant Optics DXR-8 Back Cover Prerequisite, Internal Monitor Components: passo 1, immagine 1 di 3 Infant Optics DXR-8 Back Cover Prerequisite, Internal Monitor Components: passo 1, immagine 2 di 3 Infant Optics DXR-8 Back Cover Prerequisite, Internal Monitor Components: passo 1, immagine 3 di 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Back Cover Prerequisite: passo 2, immagine 1 di 3 Infant Optics DXR-8 Back Cover Prerequisite: passo 2, immagine 2 di 3 Infant Optics DXR-8 Back Cover Prerequisite: passo 2, immagine 3 di 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Back Cover Prerequisite: passo 3, immagine 1 di 3 Infant Optics DXR-8 Back Cover Prerequisite: passo 3, immagine 2 di 3 Infant Optics DXR-8 Back Cover Prerequisite: passo 3, immagine 3 di 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
Conclusione
Altre 20 persone hanno completato questa guida.
Cal Poly, Team 13-4, Banghart Winter 2017 Membro di Cal Poly, Team 13-4, Banghart Winter 2017
CPSU-BANGHART-W17S13G4
4 Membri
4 Guide realizzate
27 Commenti
Great walkthrough. One suggestion i have is to make sure to remove the battery before doing any of the disassembly. Great guide!
Derrick Brown - Replica
Any idea where I could buy a replacement screen though? I just dropped mine and the screen is broken. The front plastic is still undamaged.
Jon Woolery - Replica
I bought a Sharp LQ035NC111 LCD Display eBay for $8.46 and it did the trick
Nathaniel Wolf -
Do you know where I could buy a replacement screen for this device? I just dropped mine and the only damage that I can see is a crack in the LCD that is making the image almost entirely unviewable.
I replaced mine with a “3.5" Inch QVGA 240x320 TFT Color LCD Display Module LQ035NC111 54pin” I found on ebay for $8.81, works great.
Just Being Helpful -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 153
Tutti i Tempi: 29,830
