Introduzione
You will need knowledge of how to use a soldering iron station. For more information regarding soldering visit: Soldering Skills
Take caution with the wires. Do not tug and pull on them with excess force.
Ensure that the hand held monitor is off and unplugged prior to starting this guide.
Secure screws to avoid losing them.
Screws are small and can pose a possible choking hazard for small children.
Cosa ti serve
Remove the four 6.0 mm Phillips screws located on the back of the hand held monitor using a Phillips #2 screwdriver.
Using a soldering iron remove the leads from the speaker on the front plate of the hand held monitor.
Altre 3 persone hanno completato questa guida.
Un commento
Great pictures! They enabled me to find the two hidden screws. I removed them (and the other obvious screws) and then bent charging pin back to intended position. The monitor is now charging again! Thanks!!
