Introduzione
Remove sections of pipe for inspection, repair, replacement, or to gain access to the pump cylinder.
Cosa ti serve
Pull the pump handle all the way down and hold it in this position, exposing the pump rod.
Place the spacer around the pump rod and under the chain attachment point.
Lift the pump lever until there is no tension in the chain and hold it in this position.
Lift the plunger assembly and separator plate and place a rod clamp below the separator plate.
Tighten the rod clamp and gently set the separator plate on top of it.
Remove the spacer.
Place a pipe coupler over the pump rod.
Install the T-handle onto the pump rod.
Have two people place C wrenches on the riser main on opposite sides of each other.
Have the two people with C-wrenches apply light upward pressure to the riser main while the base clamp operator loosens the clamp.
Lift the pipe evenly, not exceeding the comfortable lifting height of either lifter. Re-secure the base clamp once the maximum lifting height has been reached.
Lower the C-wrenches and repeat this step until the pipe coupling reaches the base clamp.
Place one pipe wrench on the exposed coupling and another on the riser main above the coupling. Have a third person stabilize the upper pipe.
Hold the wrench on the coupling steady while the wrench on the riser main is rotated counterclockwise until the pipe comes free.
Lift the upper pipe and place the rod clamp onto the pump rod below the pump rod coupling.
Lift and hold the upper pipe high enough to expose the pump rod coupling.
Place one open end wrench over the lower portion of the pump rod coupling. Hold this wrench steady.
Place another wrench on the upper portion of the pump rod coupling. Turn this wrench counterclockwise until the coupling separates.
Pull the upper pipe away from the pump and lay it on its side away from the pump.
