Introduzione
Follow this guide to remove the handle and axle of the India Mark II. You can then replace or repair either or both.
Cosa ti serve
Remove the hex head bolt from the top of the access door on the pump head.
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Use a wrench to loosen the nut on the end of the handle axle.
Remove the nut and washer from the end of the axle.
Altre 2 persone hanno completato questa guida.
