Salta al contenuto principale
India Mark II Access Door Replacement
Cosa ti serve
  1. India Mark II Access Door Replacement, Access Door: passo 1, immagine 1 di 2 India Mark II Access Door Replacement, Access Door: passo 1, immagine 2 di 2
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Remove the hex head bolt from the top of the access door on the pump head.
    • On reassembly, this bolt should be hand-tight.
  2. India Mark II Access Door Replacement: passo 2, immagine 1 di 3 India Mark II Access Door Replacement: passo 2, immagine 2 di 3 India Mark II Access Door Replacement: passo 2, immagine 3 di 3
    • Pull the access door straight up off the pump head.
    • Store the access door in a sanitary place to prevent contamination.
  3. India Mark II Access Door Replacement: passo 3, immagine 1 di 2 India Mark II Access Door Replacement: passo 3, immagine 2 di 2
    • The access door has a tongue that fits into the base of the pump head.
    • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
Conclusione
iFixit Membro di iFixit
Staff
135 Membri
16.767 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 35
Ultimi 30 Giorni: 184
Tutti i Tempi: 1,623
