Salta al contenuto principale
InFocus Screenplay 4805 Lens Replacement
Cosa ti serve
  1. InFocus Screenplay 4805 Lens Replacement, Top Panel: passo 1, immagine 1 di 3 InFocus Screenplay 4805 Lens Replacement, Top Panel: passo 1, immagine 2 di 3 InFocus Screenplay 4805 Lens Replacement, Top Panel: passo 1, immagine 3 di 3
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
  2. InFocus Screenplay 4805 Lens Replacement: passo 2, immagine 1 di 2 InFocus Screenplay 4805 Lens Replacement: passo 2, immagine 2 di 2
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
  3. InFocus Screenplay 4805 Lens Replacement: passo 3, immagine 1 di 3 InFocus Screenplay 4805 Lens Replacement: passo 3, immagine 2 di 3 InFocus Screenplay 4805 Lens Replacement: passo 3, immagine 3 di 3
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
  4. InFocus Screenplay 4805 Lens Replacement: passo 4, immagine 1 di 1
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
  5. InFocus Screenplay 4805 Lens Replacement: passo 5, immagine 1 di 1
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
  6. InFocus Screenplay 4805 Lens Replacement, Lens: passo 6, immagine 1 di 3 InFocus Screenplay 4805 Lens Replacement, Lens: passo 6, immagine 2 di 3 InFocus Screenplay 4805 Lens Replacement, Lens: passo 6, immagine 3 di 3
    • Using the Phillips #1 screwdriver, remove the (3) three 1cm black screws on the face of the lens.
    • Gently pull out the lens.
Conclusione
To reassemble the device, follow these instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 679
