Salta al contenuto principale
InFocus Screenplay 4805 Lamp Replacement
Cosa ti serve
  1. InFocus Screenplay 4805 Lamp Replacement, Remove the lamp door: passo 1, immagine 1 di 1
    • Front panel assembly removal is not required.
    • To remove the lamp door, use a metal or plastic pry tool and unclip the lamp door from the projector. Set this aside for reassembly.
  2. InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: passo 2, immagine 1 di 3 InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: passo 2, immagine 2 di 3 InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: passo 2, immagine 3 di 3
    • If you are replacing the lamp as an assembly, follow this guide in reverse from this step.
    • Remove the two gold 1 cm screws and washers on the side of lens housing using the 4.0 flat-head bit
    • Pinch the white wire tab to gently detach the side that connects with the lens housing.
  3. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 3, immagine 1 di 2 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 3, immagine 2 di 2
    • This step is only required when rebuilding the old lamp with a replacement bulb.
    • Slide the bulb housing out of the projector.
    • Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
  4. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 4, immagine 1 di 2 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 4, immagine 2 di 2
    • Gently pull the top of the bulb housing off.
    • Lift up the middle of the bulb housing to remove it.
    • Be careful of loose parts, such as the metal housing and the glass focusing lens.
  5. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 5, immagine 1 di 3 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 5, immagine 2 di 3 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 5, immagine 3 di 3
    • Unhook the spring from the bulb housing.
    • Gently remove the bulb.
Conclusione
To reassemble the device, follow these instructions in reverse order.
3 Commenti
To remove and later disassemble the lamp, you don’t need to remove whole cover. Just open the lamp bay door and follow the steps starting  from 6!
madyogi - Replica
madyogi, exactly. You are absolutely right!
ilya.zhizhin - Replica
I was able to fix an old projector I got for $40. Thank you so much for the tutorial.
Madelyn Tapia - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,489
