Introduzione
The fan is an important part of the InFocus IN35W projector, and if it fails to work, your device could overheat and break. If you do not hear the fan running in your projector, this guide will help you access it to figure out the problem.
Cosa ti serve
Use the plastic opening tool to remove the front plastic casing surrounding the lens.
Pry apart the clips securing the top and bottom of the device using the plastic opening tool.
Detach all six of the cables and speaker wires from the white connectors on the motherboard.
