Salta al contenuto principale
InFocus IN35W Daughterboard Replacement
Cosa ti serve
  1. InFocus IN35W Daughterboard Replacement, Top Plate: passo 1, immagine 1 di 3 InFocus IN35W Daughterboard Replacement, Top Plate: passo 1, immagine 2 di 3 InFocus IN35W Daughterboard Replacement, Top Plate: passo 1, immagine 3 di 3
    • Use the plastic opening tool to remove the front plastic casing surrounding the lens.
    • Pry apart the clips securing the top and bottom of the device using the plastic opening tool.
  2. InFocus IN35W Daughterboard Replacement: passo 2, immagine 1 di 2 InFocus IN35W Daughterboard Replacement: passo 2, immagine 2 di 2
    • Pull the top piece up.
    • The two gray ventilation grates will slip off the device.
  3. InFocus IN35W Daughterboard Replacement: passo 3, immagine 1 di 2 InFocus IN35W Daughterboard Replacement: passo 3, immagine 2 di 2
    • Detach the white speaker wire that connects the motherboard to the top piece.
    • Remove the top cover from the device.
  4. InFocus IN35W Daughterboard Replacement, Daughterboard: passo 4, immagine 1 di 2 InFocus IN35W Daughterboard Replacement, Daughterboard: passo 4, immagine 2 di 2
    • Remove one 7 mm screw from the silver fastening plate using a Torx T9 screwdriver.
  5. InFocus IN35W Daughterboard Replacement: passo 5, immagine 1 di 2 InFocus IN35W Daughterboard Replacement: passo 5, immagine 2 di 2
    • Remove eight 7 mm screws from the daughterboard using a Torx T9 screwdriver.
  6. InFocus IN35W Daughterboard Replacement: passo 6, immagine 1 di 2 InFocus IN35W Daughterboard Replacement: passo 6, immagine 2 di 2
    • Disconnect the red and black bundled cable from its connector on the daughterboard.
    • Grab the daughterboard by the sides and carefully lift it out from the top plate.
Conclusione
Grace Hubert
Membro da: 10/18/21
608 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 1-2, Simcock Fall 2021 Membro di UMass Dartmouth, Team 1-2, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 73
