Salta al contenuto principale
InFocus IN3104 Top Cover Replacement
Cosa ti serve
  1. InFocus IN3104 Top Cover Replacement, Top Cover: passo 1, immagine 1 di 3 InFocus IN3104 Top Cover Replacement, Top Cover: passo 1, immagine 2 di 3 InFocus IN3104 Top Cover Replacement, Top Cover: passo 1, immagine 3 di 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Top Cover Replacement: passo 2, immagine 1 di 3 InFocus IN3104 Top Cover Replacement: passo 2, immagine 2 di 3 InFocus IN3104 Top Cover Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 190
