Salta al contenuto principale
InFocus IN3104 Cooling Fan Replacement
Cosa ti serve
  1. InFocus IN3104 Cooling Fan Replacement, Top Cover: passo 1, immagine 1 di 3 InFocus IN3104 Cooling Fan Replacement, Top Cover: passo 1, immagine 2 di 3 InFocus IN3104 Cooling Fan Replacement, Top Cover: passo 1, immagine 3 di 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Cooling Fan Replacement: passo 2, immagine 1 di 3 InFocus IN3104 Cooling Fan Replacement: passo 2, immagine 2 di 3 InFocus IN3104 Cooling Fan Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Cooling Fan Replacement, InFocus IN3104 Metal Cover Disassembly: passo 3, immagine 1 di 2 InFocus IN3104 Cooling Fan Replacement, InFocus IN3104 Metal Cover Disassembly: passo 3, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  4. InFocus IN3104 Cooling Fan Replacement: passo 4, immagine 1 di 3 InFocus IN3104 Cooling Fan Replacement: passo 4, immagine 2 di 3 InFocus IN3104 Cooling Fan Replacement: passo 4, immagine 3 di 3
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
  5. InFocus IN3104 Cooling Fan Replacement, Cooling Fan: passo 5, immagine 1 di 2 InFocus IN3104 Cooling Fan Replacement, Cooling Fan: passo 5, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the three 6 mm screws on the metal cover beside the lamp.
    • The screws are in a tight location, so you may need a thin screwdriver or an extension to remove them.
  6. InFocus IN3104 Cooling Fan Replacement: passo 6, immagine 1 di 3 InFocus IN3104 Cooling Fan Replacement: passo 6, immagine 2 di 3 InFocus IN3104 Cooling Fan Replacement: passo 6, immagine 3 di 3
    • Unplug the yellow, red, and black colored cable bundle from the motherboard.
    • Remove the cooling fan from the device by lifting it out.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 515
