Salta al contenuto principale
In-Ear Headphone Control and Mic Block Disassembly
Cosa ti serve
  1. In-Ear Headphone Control and Mic Block Disassembly, The Control Unit: passo 1, immagine 1 di 1
    • Find the edge of the control unit and get a very fine flathead screw driver (or a plastic pry tool which would do less damage)
  2. In-Ear Headphone Control and Mic Block Disassembly, Opening The Unit: passo 2, immagine 1 di 1
    • Wedge the tool in the corner and start sliding it to the left.
    • As you do this slowely twist the screw driver back and forth to release the clips.
    • Try not to let the tool slip into the control unit as this may damage the circuit board inside.
  3. In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: passo 3, immagine 1 di 2 In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: passo 3, immagine 2 di 2
    • Repeat step 2 and the control unit should open as seen in the image.
    • Remove the plastic sleeves and you will be left with just the circuit board (see second image).
  4. In-Ear Headphone Control and Mic Block Disassembly, Identify Broken Wire: passo 4, immagine 1 di 1
    • It is quickly seen that one of the wires has broken away from the circuit board (see image)
  5. In-Ear Headphone Control and Mic Block Disassembly, Resolder the Broken Wire: passo 5, immagine 1 di 1
    • Once the wire is found a steady hand and a fine tipped soldering iron should be used to reattach the wire.
    • Ensure that you do not head to circuit board for too long as it may cause damage (be as quick as possible!)
    • After this, the circuit board and wires should be replaced as they were before. Press the plastic cover halves together and it should click back into place.
    • And they are fixed!
Conclusione
Your headphones should now be working!
Altre 4 persone hanno completato questa guida.
Alexander
Membro da: 09/10/18
260 Reputazione
1 Guida realizzata
Un commento
Thanks a lot this worked perfectly thank you very much
MD Ratul - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 47
Ultimi 30 Giorni: 200
Tutti i Tempi: 13,906
