Salta al contenuto principale
Impuls Blender Electronic wire Replacement
Cosa ti serve
  1. Impuls Blender Electronic wire Replacement, Electronic wire: passo 1, immagine 1 di 3 Impuls Blender Electronic wire Replacement, Electronic wire: passo 1, immagine 2 di 3 Impuls Blender Electronic wire Replacement, Electronic wire: passo 1, immagine 3 di 3
    • Here you see the Impuls blender
    • First, seperate the the blender jar from the bottom part by turning it and put it aside.
  2. Impuls Blender Electronic wire Replacement: passo 2, immagine 1 di 3 Impuls Blender Electronic wire Replacement: passo 2, immagine 2 di 3 Impuls Blender Electronic wire Replacement: passo 2, immagine 3 di 3
    • Turn the bottom part over and look at the bottom.
    • Take the rubber parts out of the 4 holes to reveal the screws.
    • Take the 4 screws out using a Phillips screwdriver.
  3. Impuls Blender Electronic wire Replacement: passo 3, immagine 1 di 3 Impuls Blender Electronic wire Replacement: passo 3, immagine 2 di 3 Impuls Blender Electronic wire Replacement: passo 3, immagine 3 di 3
    • Take the blue bottom part off the rest of the product to reveal the inside.
    • Unscrew the black piece to be able to slide the blue part away from the rest.
  4. Impuls Blender Electronic wire Replacement: passo 4, immagine 1 di 3 Impuls Blender Electronic wire Replacement: passo 4, immagine 2 di 3 Impuls Blender Electronic wire Replacement: passo 4, immagine 3 di 3
    • When you look to the inside, you see that there are two components; the buttons and the motor.
    • Unscrew the part that contains the buttons and take it off.
  5. Impuls Blender Electronic wire Replacement: passo 5, immagine 1 di 3 Impuls Blender Electronic wire Replacement: passo 5, immagine 2 di 3 Impuls Blender Electronic wire Replacement: passo 5, immagine 3 di 3
    • Take out the 3 screws that are deep inside.
    • Take off the blue part on top that was fixed with those screws.
    • Pull the black disc out by using the screwdriver as lever from multiple sides.
    • This will take some force, so do not be afraid it will break.
  6. Impuls Blender Electronic wire Replacement: passo 6, immagine 1 di 3 Impuls Blender Electronic wire Replacement: passo 6, immagine 2 di 3 Impuls Blender Electronic wire Replacement: passo 6, immagine 3 di 3
    • When you have taken off the black piece and revealed the 4 screws, unscrew them all.
    • Take out the motor part and the rest of the electronics.
  7. Impuls Blender Electronic wire Replacement: passo 7, immagine 1 di 3 Impuls Blender Electronic wire Replacement: passo 7, immagine 2 di 3 Impuls Blender Electronic wire Replacement: passo 7, immagine 3 di 3
    • Find the fraction in the wire.
    • Cut off the broken part
    • Strip both sides of the wire that have to be attached again.
  8. Impuls Blender Electronic wire Replacement: passo 8, immagine 1 di 2 Impuls Blender Electronic wire Replacement: passo 8, immagine 2 di 2
    • If you will use a shrink sleeve to cover the electronic wire, it has to be put on the wire first. Otherwise if electrical tape is used, this can be done afterwards.
    • Solder the two wires with a soldering iron.
    • Shrink the sleeve with a heater or put the electrical tape around the soldered wire.
Conclusione
To reassemble your device, follow the instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 37
Tutti i Tempi: 1,071
