Salta al contenuto principale
Impression i7 Front Camera Replacement
Cosa ti serve
  1. Impression i7 Front Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Impression i7 Front Camera Replacement: passo 2, immagine 1 di 1
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. Impression i7 Front Camera Replacement: passo 3, immagine 1 di 1
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  4. Impression i7 Front Camera Replacement: passo 4, immagine 1 di 2 Impression i7 Front Camera Replacement: passo 4, immagine 2 di 2
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  5. Impression i7 Front Camera Replacement: passo 5, immagine 1 di 1
    • Desolder the positive and negative leads.
  6. Impression i7 Front Camera Replacement: passo 6, immagine 1 di 2 Impression i7 Front Camera Replacement: passo 6, immagine 2 di 2
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
  7. Impression i7 Front Camera Replacement, Front Camera: passo 7, immagine 1 di 1
    • Gently pull the front camera connection out of its socket.
  8. Impression i7 Front Camera Replacement: passo 8, immagine 1 di 1
    • Lift the camera unit from its housing. The unit should come out with minimal force.
Conclusione
Cole Beaver
Membro da: 11/05/18
390 Reputazione
3 Guide realizzate
IUPUI, Team S1-G5, Baechle Fall 2018 Membro di IUPUI, Team S1-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G5
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 95
