Salta al contenuto principale
Imation Superdisk USB Drive Plastic Housing Replacement
Cosa ti serve
  1. Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: passo 1, immagine 1 di 2 Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: passo 1, immagine 2 di 2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Plastic Housing Replacement: passo 2, immagine 1 di 2 Imation Superdisk USB Drive Plastic Housing Replacement: passo 2, immagine 2 di 2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Plastic Housing Replacement: passo 3, immagine 1 di 2 Imation Superdisk USB Drive Plastic Housing Replacement: passo 3, immagine 2 di 2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Plastic Housing Replacement: passo 4, immagine 1 di 2 Imation Superdisk USB Drive Plastic Housing Replacement: passo 4, immagine 2 di 2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Plastic Housing Replacement: passo 5, immagine 1 di 2 Imation Superdisk USB Drive Plastic Housing Replacement: passo 5, immagine 2 di 2
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  6. Imation Superdisk USB Drive Plastic Housing Replacement: passo 6, immagine 1 di 2 Imation Superdisk USB Drive Plastic Housing Replacement: passo 6, immagine 2 di 2
    • Slide the metal housing out of the plastic shell.
Conclusione
Ohio State, Team 1-2, Buehl Spring 2014 Membro di Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 805
