Salta al contenuto principale
Imation Superdisk USB Drive Daughter Board Replacement
Cosa ti serve
  1. Imation Superdisk USB Drive Daughter Board Replacement, Plastic Housing: passo 1, immagine 1 di 2 Imation Superdisk USB Drive Daughter Board Replacement, Plastic Housing: passo 1, immagine 2 di 2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Daughter Board Replacement: passo 2, immagine 1 di 2 Imation Superdisk USB Drive Daughter Board Replacement: passo 2, immagine 2 di 2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Daughter Board Replacement: passo 3, immagine 1 di 2 Imation Superdisk USB Drive Daughter Board Replacement: passo 3, immagine 2 di 2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Daughter Board Replacement: passo 4, immagine 1 di 2 Imation Superdisk USB Drive Daughter Board Replacement: passo 4, immagine 2 di 2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Daughter Board Replacement: passo 5, immagine 1 di 2 Imation Superdisk USB Drive Daughter Board Replacement: passo 5, immagine 2 di 2
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  6. Imation Superdisk USB Drive Daughter Board Replacement: passo 6, immagine 1 di 2 Imation Superdisk USB Drive Daughter Board Replacement: passo 6, immagine 2 di 2
    • Slide the metal housing out of the plastic shell.
  7. Imation Superdisk USB Drive Daughter Board Replacement, Metal Casing: passo 7, immagine 1 di 2 Imation Superdisk USB Drive Daughter Board Replacement, Metal Casing: passo 7, immagine 2 di 2
    • Slide metal panel out of the metal casing.
  8. Imation Superdisk USB Drive Daughter Board Replacement: passo 8, immagine 1 di 2 Imation Superdisk USB Drive Daughter Board Replacement: passo 8, immagine 2 di 2
    • Slide disk drive out of metal casing.
  9. Imation Superdisk USB Drive Daughter Board Replacement, Daughter Board: passo 9, immagine 1 di 1
    • Flip the disk drive over so the the plug on the daughter board is visible.
  10. Imation Superdisk USB Drive Daughter Board Replacement: passo 10, immagine 1 di 2 Imation Superdisk USB Drive Daughter Board Replacement: passo 10, immagine 2 di 2
    • Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit.
  11. Imation Superdisk USB Drive Daughter Board Replacement: passo 11, immagine 1 di 2 Imation Superdisk USB Drive Daughter Board Replacement: passo 11, immagine 2 di 2
    • Gently pull on the daughter board until it separates from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Darlena
Membro da: 02/11/14
219 Reputazione
3 Guide realizzate
Ohio State, Team 1-2, Buehl Spring 2014 Membro di Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 32
Tutti i Tempi: 954
