Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide is to help you step by step on how to replace the daughter board to the Imation Supserdisk USB drive.
Parti
Nessuna parte specificata.
  1. Flip the device over so the bottom is facing up. You will know it is the bottom because there will be six silver screws visible.
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Remove the USB converter device by gently pulling it out. Do not pull the converter device out by the cord.
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Remove the six silver screws using a small Phillips head screwdriver. Remove the six silver screws using a small Phillips head screwdriver.
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel. Lift panel free of device.
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Remove the plastic end cap by sliding it forward, freeing from the rest of the device. You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  7. Slide the metal housing out of the plastic shell. Slide the metal housing out of the plastic shell.
    • Slide the metal housing out of the plastic shell.
  8. Slide metal panel out of the metal casing. Slide metal panel out of the metal casing.
    • Slide metal panel out of the metal casing.
  9. Slide disk drive out of metal casing. Slide disk drive out of metal casing.
    • Slide disk drive out of metal casing.
  10. Flip the disk drive over so the the plug on the daughter board is visible.
    • Flip the disk drive over so the the plug on the daughter board is visible.
  11. Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit. Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit.
    • Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit.
  12. Gently pull on the daughter board until it separates from the device. Gently pull on the daughter board until it separates from the device.
    • Gently pull on the daughter board until it separates from the device.
Conclusione
Darlena
Membro da: 11/02/2014
201 Reputazione
3 Guide realizzate
Ohio State, Team 1-2, Buehl Spring 2014 Membro di Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 408
