Salta al contenuto principale
Ikea Hektar Lamp Foot Pedal Switch Button Replacement
Cosa ti serve
  1. Ikea Hektar Lamp Foot Pedal Switch Button Replacement, Foot Pedal Lamp Switch Button: passo 1, immagine 1 di 2 Ikea Hektar Lamp Foot Pedal Switch Button Replacement, Foot Pedal Lamp Switch Button: passo 1, immagine 2 di 2
    • Unplug the lamp from the power source.
    • Do not touch the metal prongs sticking out of the connector, only hold by the plastic section of the chord.
    • Find a well-lit area to work in and begin your repair.
  2. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 2, immagine 1 di 3 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 2, immagine 2 di 3 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 2, immagine 3 di 3
    • Flip the lamp switch upside down.
    • Use a Phillips #0 screwdriver to remove the four 6 mm screws from the bottom of the foot pedal while holding the button cap in place.
  3. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 3, immagine 1 di 2 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 3, immagine 2 di 2
    • Lift the top off of the foot pedal that holds the button in place and put it to the side.
    • Remove the damaged button from the switch and place it to the side.
  4. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 4, immagine 1 di 1
    • Briefly inspect the spring and electrical wiring for any visual damage.
    • If no internal damage is visible, continue to the next step.
  5. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 5, immagine 1 di 2 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 5, immagine 2 di 2
    • Replace the button and top of the foot pedal.
    • The button must be replaced before the cap to be held in place.
  6. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 6, immagine 1 di 3 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 6, immagine 2 di 3 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 6, immagine 3 di 3
    • Flip the pedal switch upside down.
    • Use a Phillips #0 screwdriver to replace the four 6 mm screws on the back while holding the switch together.
  7. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 7, immagine 1 di 2 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 7, immagine 2 di 2
    • Inspect the switch for any gaps around the edge.
    • Press down on the button to make sure you hear and/or feel a click.
  8. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 8, immagine 1 di 1
    • All done! Now you have a fully functional foot pedal lamp switch.
Conclusione
Jesus Ortiz
Membro da: 03/15/24
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 58
Tutti i Tempi: 446
