Salta al contenuto principale
Ibanez Overdrive Battery Replacement
Cosa ti serve
  1. Ibanez Overdrive Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Before replacing the battery, ensure the stompbox is turned off and disconnected from the power supply.
    • The red LED top of the potentiometer means the stompbox is on. No light from LED means the stompbox is off.
  2. Ibanez Overdrive Battery Replacement: passo 2, immagine 1 di 3 Ibanez Overdrive Battery Replacement: passo 2, immagine 2 di 3 Ibanez Overdrive Battery Replacement: passo 2, immagine 3 di 3
    • Verify the stompbox is off, before doing any repairs.
    • Rotate the stompbox onto its back. There will be four screws. Using a 1/4 Phillip screwdriver, remove all four screws from the back plate.
    • Remove all four screws by turning them counterclockwise.
  3. Ibanez Overdrive Battery Replacement: passo 3, immagine 1 di 3 Ibanez Overdrive Battery Replacement: passo 3, immagine 2 di 3 Ibanez Overdrive Battery Replacement: passo 3, immagine 3 di 3
    • Remove the back plate of the stompbox by lifting the backplate upwards.
    • Next, locate the 9-volt battery, which should be at the bottom of the overdrive stompbox, and carefully pull apart the battery from the battery clip connector.
  4. Ibanez Overdrive Battery Replacement: passo 4, immagine 1 di 3 Ibanez Overdrive Battery Replacement: passo 4, immagine 2 di 3 Ibanez Overdrive Battery Replacement: passo 4, immagine 3 di 3
    • After removing the depleted battery, insert a new 9-volt battery. Ensure the battery and battery clip connector are connected as shown in the photo.
    • After connecting the battery and battery clip connector, carefully reposition both items to their original position, as shown in the photo.
  5. Ibanez Overdrive Battery Replacement: passo 5, immagine 1 di 3 Ibanez Overdrive Battery Replacement: passo 5, immagine 2 di 3 Ibanez Overdrive Battery Replacement: passo 5, immagine 3 di 3
    • Once the battery is positioned at its original position, reattach the back plate.
    • Using a 1/4 Phillip screwdriver, re-screw all four screws onto the back plate.
    • Reattach all four screws by turning them clockwise.
Linea Traguardo
Juan Colon
Membro da: 03/20/24
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 104
