Salta al contenuto principale
IT-Riage Rev 3 Cylinder Disassembly
Cosa ti serve
  1. IT-Riage Rev 3 Cylinder  Disassembly, IT-Riage Rev 3 Cylinder  Disassembly: passo 1, immagine 1 di 2 IT-Riage Rev 3 Cylinder  Disassembly, IT-Riage Rev 3 Cylinder  Disassembly: passo 1, immagine 2 di 2
    • This is what the chair will look like like without the footrest. to remove the footrest . You need to unplug the power cable and air hose behind the footrest . Then using a flat head screw driver remove the clips on either side by sliding the tip of screw driver in the clip and simultaneously lifting up on the clip.
  2. IT-Riage Rev 3 Cylinder  Disassembly: passo 2, immagine 1 di 2 IT-Riage Rev 3 Cylinder  Disassembly: passo 2, immagine 2 di 2
    • Using a Philips screw driver remove the 6 screws holding on these 2 front panels. one removed they come off in 2 pieces be gentle with them as they are flimsy plastic.
  3. IT-Riage Rev 3 Cylinder  Disassembly: passo 3, immagine 1 di 1
    • Once the front panels are out of the way you should spot the Recline/ Zero Gravity Motor . NOT TO BE CONFUSED with the footrest motor . The footrest motor is the motor with a Wheel attachment on the end . Grease the recline cylinder by reclining the chair and once fully actuated apply grease as needed.
Conclusione
To reassemble your device, follow these instructions in reverse order. Be aware when re attaching front panels that the panels going on in the correct order. If done incorrectly they could be damaged upon operation of the chair.
Nick
Membro da: 05/30/17
2.764 Reputazione
16 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 111
