Introduzione
All Screws in here will be color coded , example : Red and Orange on the same step means there are 2 different types of screws on that step.
Cosa ti serve
Remove 8 screws marked in red .
Remove 3 screws marked in Orange
PLEASE REMEMBER THE FOLLOWING DURING REASSEMBLY:
- When gluing the foam to the plastic DON'T over do it , just spray for a second on the desired area and press foam onto glue.
- When Gluing the foam be sure your edges are smooth and everything is secured , other wise you will get bumps in the leather .
- There will be wrinkles on the leather when its re stretched , this is normal . They usually dissipate over time.
- If the Bolts from step 2 will not go on use a utility knife and cut X shaped holes on the leather until you can physically see the thread .
- When attaching the 3 wires and 1 hose from step 3 BE SURE these are not getting pinched between the upper and lower portion. Otherwise you will get no air to the feet area.
Good Luck .
Good Luck .
