Salta al contenuto principale
IKEA KOPPLA Connector (fix)
Cosa ti serve
  1. IKEA KOPPLA Connector (fix), break open the adapter: passo 1, immagine 1 di 3 IKEA KOPPLA Connector (fix), break open the adapter: passo 1, immagine 2 di 3 IKEA KOPPLA Connector (fix), break open the adapter: passo 1, immagine 3 di 3
    • open device , using brute force is the only option because it's ultrasonic welded together.
    • use screw driver or squeeze in a vice to crack it open.''
  2. IKEA KOPPLA Connector (fix), Fixing the issue (broken solderpoints): passo 2, immagine 1 di 2 IKEA KOPPLA Connector (fix), Fixing the issue (broken solderpoints): passo 2, immagine 2 di 2
    • Resolder all the USB connector pins (red box'es), on all 3 USB connectors to be sure they are functional. (on this image the top one is defective)
    • The reason solder points break is the connector support is soldered onto the board on one side only. Not by the arrow. Thereby adding stress directly to the soldered pins.
    • In addition the connector pin (square) near the U2 marking is too short and therefore may not be soldered properly.
    • see 2nd image for example of front support pin is pulled out of solder area.
  3. IKEA KOPPLA Connector (fix), add glue to connectors: passo 3, immagine 1 di 2 IKEA KOPPLA Connector (fix), add glue to connectors: passo 3, immagine 2 di 2
    • add hot melt glue in these areas on the board and on the side of the connector.
    • Add the cover first to understand where there is room for it in the cover.
    • If connector is not glued, it is likely the charger will stop working again in the near future.
    • Ikea have been notified of this issue.
    • To seal the enclosure , add suitable glue to edge, and press the top/bottom together.
    • Use as vice while holding them together, while the glue hardens.
Conclusione
I understand these adapters are cheap, but they can be repaired as described.
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 54
Tutti i Tempi: 2,757
