Salta al contenuto principale
IKEA Drill Battery Replacement
Cosa ti serve
  1. IKEA Drill Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Use a 4 mm Phillips screwdriver to remove the seven screws to disassemble the housing of the drill.
  2. IKEA Drill Battery Replacement: passo 2, immagine 1 di 1
    • Remove the sticker carefully from the bottom.
  3. IKEA Drill Battery Replacement: passo 3, immagine 1 di 1
    • Open the housing of the drill.
    • While opening place the rotation switch apart.
    • Detach the electric circuit and place it next to the drill.
  4. IKEA Drill Battery Replacement: passo 4, immagine 1 di 1
    • Cut each tubing from the three wires of the battery with a utility knife.
  5. IKEA Drill Battery Replacement: passo 5, immagine 1 di 2 IKEA Drill Battery Replacement: passo 5, immagine 2 di 2
    • Disconnect the three wires of the battery with a soldering iron.
  6. IKEA Drill Battery Replacement: passo 6, immagine 1 di 1
    • Place each new tubing (three in total) on the battery wires through sliding them on each wire.
  7. IKEA Drill Battery Replacement: passo 7, immagine 1 di 1
    • Attach the two batteries to each other with tape, in case you have two separate batteries.
    • Use solder and a solder iron to attach the new battery to the wires.
    • The black wire should be connected with the negative pole of the two-wire side.
    • The wire should be warm enough to solder the battery to the wire.
    • Slide the tubings on each connection and heat each tubing with a lighter to make them shrink.
  8. IKEA Drill Battery Replacement: passo 8, immagine 1 di 1
    • Place the electric circuit and the rotation switch back into the housing.
  9. IKEA Drill Battery Replacement: passo 9, immagine 1 di 1
    • Put the housing back on the drill through clicking and closing it.
    • Put the seven screws back into the housing with the Phillips screwdriver.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
5 Commenti
The difficult and dangerous operation is the tag connection to the Li-ion battery case. The Weller soldering iron shown in (7) has the wrong shape solder tip. The connection to a Li-ion must be made quickly and without significant heating of the Li-ion. Connections are usually spot welded but an amateur could try a solder gun.
The replacement batteries should be Li-ion size 18650 of at least 1500 mAh and identical. These are available with tags already attached and I would buy these and crimp to the tags. I have not done this myself because I found the receipt and the drill was bought 3 years ago so it is going back. The batteries were manufactured 4 years before I bought the drill so they were old when I bought it.
kaydee - Replica
Anyone know where I can get new brushes for the motor? Or a motor itself? Everything else works fine on my now 12 year old drill!
Charlie Nancarrow - Replica
Where can I buy the these battery
Dragons International Trading - Replica
Kenapa bor dicasindikat
SNIPER NGAPRAK - Replica
Where I can find charging pcb?
Rahul - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 91
Tutti i Tempi: 12,147
