Salta al contenuto principale
IBM Thinkpad T61 Trackpad Replacement
Cosa ti serve
  1. IBM Thinkpad T61 Trackpad Replacement, Trackpad: passo 1, immagine 1 di 1
    • Flip your computer over and remove the four indicated screws with the Phillips #1 screwdriver.
  2. IBM Thinkpad T61 Trackpad Replacement: passo 2, immagine 1 di 1
    • With the screws removed, the trackpad panel should lift as shown. Gently lift so the inside is visible.
  3. IBM Thinkpad T61 Trackpad Replacement: passo 3, immagine 1 di 2 IBM Thinkpad T61 Trackpad Replacement: passo 3, immagine 2 di 2
    • Gently remove the white plug to disconnect the trackpad panel from the bottom of the computer.
    • Use the screwdriver to remove the four screws from the trackpad. Two of the screws are located just under the plastic.
  4. IBM Thinkpad T61 Trackpad Replacement: passo 4, immagine 1 di 3 IBM Thinkpad T61 Trackpad Replacement: passo 4, immagine 2 di 3 IBM Thinkpad T61 Trackpad Replacement: passo 4, immagine 3 di 3
    • Separate the trackpad with the bottom mouse buttons from the trackpad panel.
  5. IBM Thinkpad T61 Trackpad Replacement: passo 5, immagine 1 di 1
    • Align the new trackpad so the screw holes line up with their insertion points. Replace the screws with the screwdriver.
  6. IBM Thinkpad T61 Trackpad Replacement: passo 6, immagine 1 di 1
    • Reinsert the white plug.
  7. IBM Thinkpad T61 Trackpad Replacement: passo 7, immagine 1 di 2 IBM Thinkpad T61 Trackpad Replacement: passo 7, immagine 2 di 2
    • Replace the trackpad panel.
    • Use the screwdriver to replace the screws, refastening the trackpad panel to the computer.
Conclusione
Replace the battery and plug in your computer. Test out your new trackpad!
Altre 6 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,774
