Salta al contenuto principale
IBM Thinkpad T61 RAM Replacement
Cosa ti serve
  1. IBM Thinkpad T61 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure the laptop has been properly shut down and unplugged.
    • Turn the computer over so that you can see the battery release tab located near the top of the Thinkpad.
  2. IBM Thinkpad T61 RAM Replacement: passo 2, immagine 1 di 1
    • Use your finger to slide the release tab to the unlocked symbol.
  3. IBM Thinkpad T61 RAM Replacement: passo 3, immagine 1 di 3 IBM Thinkpad T61 RAM Replacement: passo 3, immagine 2 di 3 IBM Thinkpad T61 RAM Replacement: passo 3, immagine 3 di 3
    • Hold the tab in the unlocked position and push the battery away from the computer to remove it.
  4. IBM Thinkpad T61 RAM Replacement: passo 4, immagine 1 di 1
    • Slide the new battery in until it clicks.
    • Ensure that the release tab is in the locked position.
  5. IBM Thinkpad T61 RAM Replacement, RAM: passo 5, immagine 1 di 1
    • Using a #0 Phillips screwdriver, remove four 17.0mm screws on the back of the computer.
    • These screws have a RAM symbol next to them.
  6. IBM Thinkpad T61 RAM Replacement: passo 6, immagine 1 di 1
    • Flip back over and open the laptop.
    • Lift up on the inside front panel just below the edge of the keyboard.
  7. IBM Thinkpad T61 RAM Replacement: passo 7, immagine 1 di 1
    • The green rectangles under the front panel are the RAM.
  8. IBM Thinkpad T61 RAM Replacement: passo 8, immagine 1 di 3 IBM Thinkpad T61 RAM Replacement: passo 8, immagine 2 di 3 IBM Thinkpad T61 RAM Replacement: passo 8, immagine 3 di 3
    • Press out on the two tabs on either side of the ram at the same time.
    • The RAM will release and pop up at a 25 degree angle.
  9. IBM Thinkpad T61 RAM Replacement: passo 9, immagine 1 di 1
    • Pull the RAM away from the housing to remove.
Conclusione
Altre 15 persone hanno completato questa guida.
Kyle
Membro da: 04/18/13
458 Reputazione
4 Guide realizzate
Cal Poly, Team 8-58, Johann Spring 2013 Membro di Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 64
Tutti i Tempi: 8,949
