Salta al contenuto principale
IBM Thinkpad T60 Hard Drive Replacement
Cosa ti serve
  1. IBM Thinkpad T60 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Turn the Thinkpad over so you can see the back.
    • Locate this screw in the bottom left-hand corner.
  2. IBM Thinkpad T60 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Using a #0 Phillips screwdriver, remove the 17.0 mm screw.
  3. IBM Thinkpad T60 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Carefully remove the plastic piece covering the hard drive port by pulling perpendicular to the side of the laptop.
  4. IBM Thinkpad T60 Hard Drive Replacement: passo 4, immagine 1 di 2 IBM Thinkpad T60 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Use a small screwdriver to locate the black ribbon.
    • With the screwdriver, pull the black tab out of the slot.
  5. IBM Thinkpad T60 Hard Drive Replacement: passo 5, immagine 1 di 2 IBM Thinkpad T60 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Pull gently on the black ribbon and the metal tray carrying the hard drive will slide out.
  6. IBM Thinkpad T60 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Remove the black plastic coverings on either side of the hard drive.
    • There is not a hard drive in this example, but the process is the same regardless.
Conclusione
Altre 9 persone hanno completato questa guida.
Cal Poly, Team 7-9, Maness Winter 2013 Membro di Cal Poly, Team 7-9, Maness Winter 2013
CPSU-MANESS-W13S7G9
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 67
Tutti i Tempi: 11,073
