Salta al contenuto principale
IBM ThinkPad t43 WiFi Card Replacement
Cosa ti serve
  1. IBM ThinkPad t43 WiFi Card Replacement, WiFi Card: passo 1, immagine 1 di 2 IBM ThinkPad t43 WiFi Card Replacement, WiFi Card: passo 1, immagine 2 di 2
    • Start with the laptop with the side with the logo facing down.
    • Next you will have to remove all the screws in the red circles
    • When removing the screws try to place them in order of removal on a magnetic pad. It will help when you put them back and lowers the chance of losing them
  2. IBM ThinkPad t43 WiFi Card Replacement: passo 2, immagine 1 di 2 IBM ThinkPad t43 WiFi Card Replacement: passo 2, immagine 2 di 2
    • Flip the laptop so that the logo is now facing up
    • locate the lock switch on the front right
    • Slide the switch to the right to unlock the laptop
    • Make sure to unlock the laptop before opening because the keyboard may still be attached
  3. IBM ThinkPad t43 WiFi Card Replacement: passo 3, immagine 1 di 2 IBM ThinkPad t43 WiFi Card Replacement: passo 3, immagine 2 di 2
    • Lift open the laptop
    • The keyboard should be detached from the bottom part of the laptop
    • Hold the edges of the keyboard and slowly pull up until it opens
    • Do not pull off the keyboard completely because there is a ribbon cable attached
  4. IBM ThinkPad t43 WiFi Card Replacement: passo 4, immagine 1 di 2 IBM ThinkPad t43 WiFi Card Replacement: passo 4, immagine 2 di 2
    • Disconnect the ribbon cable by simply lifting it up
  5. IBM ThinkPad t43 WiFi Card Replacement: passo 5, immagine 1 di 1
    • The WiFi-Card is located towards the middle bottom of the laptop
  6. IBM ThinkPad t43 WiFi Card Replacement: passo 6, immagine 1 di 2 IBM ThinkPad t43 WiFi Card Replacement: passo 6, immagine 2 di 2
    • Locate the two wires connected at the top of the WiFi-Card
    • Hold the card down and use the tweezers to pinch the plug and pull up.
  7. IBM ThinkPad t43 WiFi Card Replacement: passo 7, immagine 1 di 3 IBM ThinkPad t43 WiFi Card Replacement: passo 7, immagine 2 di 3 IBM ThinkPad t43 WiFi Card Replacement: passo 7, immagine 3 di 3
    • Place fingers on the two clips holding the card in place
    • Pull the clips outwards until the the card pops up
    • Pull the card out by pulling out away from your body
    • To replace, follow these steps in reverse order
    • Make sure that the side with the short end is on the left when you put it back in.
Conclusione
Altre 2 persone hanno completato questa guida.
aLiX pIeRRe
Membro da: 03/19/18
855 Reputazione
5 Guide realizzate
2 Commenti
I need to know what's role of the cables AUX and MAIN because i cut one
M a n i _001 - Replica
AUX and MAIN cables are antenna cables. In this laptop there are two antennas, MAIN and AUX.
If you have a soldering iron, simply solder the two parts of the cable you cut and everything is gonna be fine.
I also recommend using shrink tubing to isolate the soldered part.
Note : laptop can work without this câble, but WiFi speed and stability will suffer.
If you can't solder the câble or can't by a new one, you can try to use only main by pluggin the only remaining antena câble to MAIN and leaving AUX unlpuged.
Brendan -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 145
Tutti i Tempi: 10,380
