Salta al contenuto principale
IBM ThinkPad T42 Speakers Replacement
Cosa ti serve
  1. IBM ThinkPad T42 Speakers Replacement, Bottom cover: passo 1, immagine 1 di 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Speakers Replacement, Rear screws: passo 2, immagine 1 di 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. IBM ThinkPad T42 Speakers Replacement, Keyboard and Trackpad: passo 3, immagine 1 di 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Speakers Replacement: passo 4, immagine 1 di 2 IBM ThinkPad T42 Speakers Replacement: passo 4, immagine 2 di 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Speakers Replacement, Lower Bracket: passo 5, immagine 1 di 2 IBM ThinkPad T42 Speakers Replacement, Lower Bracket: passo 5, immagine 2 di 2
    • Grasp the metal bracket to remove it from the device.
  6. IBM ThinkPad T42 Speakers Replacement, Microphone cover: passo 6, immagine 1 di 1
    • Remove the rubber cover from the microphone.
  7. IBM ThinkPad T42 Speakers Replacement, Speakers: passo 7, immagine 1 di 2 IBM ThinkPad T42 Speakers Replacement, Speakers: passo 7, immagine 2 di 2
    • Check to ensure the speaker cartridge moves freely before removing the cartridge.
    • Disconnect the speaker wire from the unit and carefully remove the speaker.
Conclusione
Cal Poly, Team 29-76, Johann Spring 2010 Membro di Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Membri
35 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 5,282
