Introduzione
Removing the optical drive is extremely easy and will only a take a minute.
Parti
Nessuna parte richiesta.
  1. Remove the single screw holding the optical drive on the underside of the laptop
    • Remove the single screw holding the optical drive on the underside of the laptop
  2. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. Push the small slider to unlock position, a tab will automatically pop out.
    • Push the small slider to unlock position, a tab will automatically pop out.
  4. Pull the tab to dislodge the optical drive, then carefully pull the drive out.
    • Pull the tab to dislodge the optical drive, then carefully pull the drive out.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 29-76, Johann Spring 2010 Membro di Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Membri
30 Guide realizzate
What’s the interface for the optical drive? SATA? IDE?
Jonas Gamao - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 4,969
