Salta al contenuto principale
IBM ThinkPad T42 Mini-PCI Port Replacement
Cosa ti serve
  1. IBM ThinkPad T42 Mini-PCI Port Replacement, Bottom cover: passo 1, immagine 1 di 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Mini-PCI Port Replacement, Rear screws: passo 2, immagine 1 di 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. IBM ThinkPad T42 Mini-PCI Port Replacement, Keyboard and Trackpad: passo 3, immagine 1 di 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Mini-PCI Port Replacement: passo 4, immagine 1 di 2 IBM ThinkPad T42 Mini-PCI Port Replacement: passo 4, immagine 2 di 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Mini-PCI Port Replacement, Port Bracket: passo 5, immagine 1 di 1
    • Remove the screw affixing the bracket down.
  6. IBM ThinkPad T42 Mini-PCI Port Replacement, Bracket Removal: passo 6, immagine 1 di 1
    • Lift the bracket up and out.
  7. IBM ThinkPad T42 Mini-PCI Port Replacement, Port Removal: passo 7, immagine 1 di 1
    • Carefully disconnect it from the motherboard and pull it out of the device.
Conclusione
Cal Poly, Team 29-76, Johann Spring 2010 Membro di Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Membri
35 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 4,393
