Salta al contenuto principale
IBM ThinkPad T42 Hard Drive Replacement
Cosa ti serve
  1. IBM ThinkPad T42 Hard Drive Replacement, Battery Clips: passo 1, immagine 1 di 1
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
  2. IBM ThinkPad T42 Hard Drive Replacement, Removing the Battery: passo 2, immagine 1 di 1
    • Carefully grab the battery, then pull it straight out, not at an angle.
  3. IBM ThinkPad T42 Hard Drive Replacement, Hard Drive Screw: passo 3, immagine 1 di 1
    • Unscrew the single screw holding the drive cage in place.
  4. IBM ThinkPad T42 Hard Drive Replacement, Sliding Drive Out: passo 4, immagine 1 di 1
    • Pull the hard drive out with of its bay the help of pictured ridges. Carefully remove it.
    • It might help to open the display slightly.
  5. IBM ThinkPad T42 Hard Drive Replacement, Removal of HDD: passo 5, immagine 1 di 1
    • Pull the Hard Drive out and proceed with replacement.
Conclusione
Altre 7 persone hanno completato questa guida.
Austin Kidd
Membro da: 04/21/10
317 Reputazione
3 Guide realizzate
Cal Poly, Team 29-76, Johann Spring 2010 Membro di Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Membri
35 Guide realizzate
Un commento
Excelente guía. Gracias
Luis Aguilar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 89
Tutti i Tempi: 20,643
