Salta al contenuto principale
IBM ThinkPad T30 RAM Replacement
Cosa ti serve
  1. IBM ThinkPad T30 RAM Replacement, Battery: passo 1, immagine 1 di 3 IBM ThinkPad T30 RAM Replacement, Battery: passo 1, immagine 2 di 3 IBM ThinkPad T30 RAM Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 RAM Replacement, RAM: passo 2, immagine 1 di 2 IBM ThinkPad T30 RAM Replacement, RAM: passo 2, immagine 2 di 2
    • Remove the 4 mm Phillips #0 screw located on the panel on the bottom right of the ThinkPad.
    • Lift up the cover and set it aside.
  3. IBM ThinkPad T30 RAM Replacement: passo 3, immagine 1 di 2 IBM ThinkPad T30 RAM Replacement: passo 3, immagine 2 di 2
    • Locate the four white tabs. There are two sets of white tabs, the top two holding the first RAM stick and the bottom holding the second RAM stick.
    • Removing one set at a time, press down on the white tabs at the same time. The RAM stick will pop out of place.
  4. IBM ThinkPad T30 RAM Replacement: passo 4, immagine 1 di 2 IBM ThinkPad T30 RAM Replacement: passo 4, immagine 2 di 2
    • Lift out the two RAM sticks.
Conclusione
Cal Poly, Team 3-20, Amido Fall 2012 Membro di Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Membri
16 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 3,761
