Salta al contenuto principale
IBM ThinkPad T30 Optical Drive Replacement
Cosa ti serve
  1. IBM ThinkPad T30 Optical Drive Replacement, Battery: passo 1, immagine 1 di 3 IBM ThinkPad T30 Optical Drive Replacement, Battery: passo 1, immagine 2 di 3 IBM ThinkPad T30 Optical Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Optical Drive Replacement, Optical Drive: passo 2, immagine 1 di 1
    • Locate the 4.8mm Phillips #0 screw on the far left of the ThinkPad, closest to the edge and above the battery, and unscrew it with a Phillips #0 screwdriver.
  3. IBM ThinkPad T30 Optical Drive Replacement: passo 3, immagine 1 di 2 IBM ThinkPad T30 Optical Drive Replacement: passo 3, immagine 2 di 2
    • On the side of the ThinkPad, locate a lock next to the optical drive. Use your fingernail to slide the lock to the right.
  4. IBM ThinkPad T30 Optical Drive Replacement: passo 4, immagine 1 di 2 IBM ThinkPad T30 Optical Drive Replacement: passo 4, immagine 2 di 2
    • Once it is unlocked, a small tab will pop out. Pull on the tab with your fingers.
    • The optical drive will easily slide out. Remove the optical drive.
Conclusione
Alex Kost
Membro da: 10/05/12
271 Reputazione
5 Guide realizzate
Cal Poly, Team 3-20, Amido Fall 2012 Membro di Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,894
