Salta al contenuto principale
IBM ThinkPad A31 Display Replacement
Cosa ti serve
  1. IBM ThinkPad A31 Display Replacement, Keyboard: passo 1, immagine 1 di 3 IBM ThinkPad A31 Display Replacement, Keyboard: passo 1, immagine 2 di 3 IBM ThinkPad A31 Display Replacement, Keyboard: passo 1, immagine 3 di 3
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  2. IBM ThinkPad A31 Display Replacement: passo 2, immagine 1 di 2 IBM ThinkPad A31 Display Replacement: passo 2, immagine 2 di 2
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  3. IBM ThinkPad A31 Display Replacement: passo 3, immagine 1 di 3 IBM ThinkPad A31 Display Replacement: passo 3, immagine 2 di 3 IBM ThinkPad A31 Display Replacement: passo 3, immagine 3 di 3
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
  4. IBM ThinkPad A31 Display Replacement, Display: passo 4, immagine 1 di 2 IBM ThinkPad A31 Display Replacement, Display: passo 4, immagine 2 di 2
    • Remove the one 21mm screw
    • Remove the 6mm screw
  5. IBM ThinkPad A31 Display Replacement: passo 5, immagine 1 di 2 IBM ThinkPad A31 Display Replacement: passo 5, immagine 2 di 2
    • Take the tool and run it under the black case.
  6. IBM ThinkPad A31 Display Replacement: passo 6, immagine 1 di 3 IBM ThinkPad A31 Display Replacement: passo 6, immagine 2 di 3 IBM ThinkPad A31 Display Replacement: passo 6, immagine 3 di 3
    • Unscrew the 2 (17mm) screws
    • Unscrew the 6mm screw
  7. IBM ThinkPad A31 Display Replacement: passo 7, immagine 1 di 2 IBM ThinkPad A31 Display Replacement: passo 7, immagine 2 di 2
    • Gently disconnect the white display ribbon cable
    • Pulling on the ribbon cable too hard could result in worse or faulty connection.
  8. IBM ThinkPad A31 Display Replacement: passo 8, immagine 1 di 3 IBM ThinkPad A31 Display Replacement: passo 8, immagine 2 di 3 IBM ThinkPad A31 Display Replacement: passo 8, immagine 3 di 3
    • Unscrew 4 (6mm) screws
    • Lift screen straight up
    • If not lifted straight up the screen could get damaged
Conclusione
Sean Tocci
Membro da: 03/19/18
293 Reputazione
2 Guide realizzate
Un commento
i have that but display is
not work
Ahmed Elwy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 479
